Suibpanel grounding
Old 05-05-08, 09:27 AM
Suibpanel grounding
Hi again.
In my remodel, I am having to modify both my subpanels so that they have a separate grounds and neutrals.
In my smaller 100A subpanel, the ground wire is a tad short to reach where my ground bus bar will be.
Is it OK to use a lug to attach the ground wire to the metal panel box and have the ground bar a short distance away, obviously also attached to the metal box?
Thanks.
Old 05-05-08, 09:33 AM
Received 42 Votes on 40 Posts
Ground wire for a 100A panel should be #8 copper, so you can just use a big wirenut to extend it. You could also use something like a crimp-on buttsplice connector to length the wire. You could also install an add-on ground bar where the wire will reach.
