Please explain this old wiring.
Old 05-18-08, 06:03 PM
New Member
I replaced a few lights in my Sisters house, I found odd situations with the wiring.
When the switch is turned off both wires read 120V to ground but nothing across them. When the switch is turned on only one wire reads 120V to ground, the other one is dead, it now reads 120V across them.
This was confirmed with my Klein Wiggy, my Fluke DMM, and my Fluke hot stick.
It's an old house with old wiring, altho the 100A panel is relatively new.
The old lights all worked with this wiring so I hooked up the new lights and they also work.
So what's going on here?
Old 05-18-08, 06:15 PM
Could be an illegal California 3-way. In this very dangerous configuration, they sent the load two hot wires as an alternative way of turning it off.
Either that or it's phantom voltage, but your wiggy should not be fooled by that.
Old 05-18-08, 06:18 PM
New Member
Thanks for the reply. Only one of the lights was a 3 way, the others were normal. Is there something they could have done to make the normal switches work like that?
Old 05-18-08, 06:26 PM
Yes, a California 3-way makes ordinary switches (i.e., not 3-way switches) work like 3-way switches.
Old 05-18-08, 06:30 PM
New Member
I'll look into that, thanks!
Old 05-18-08, 09:19 PM
Tolyn Ironhand's Avatar
Received 67 Votes on 59 Posts
I have run across in some older homes where they switch the neutral. That may be something to watch for.
Old 05-18-08, 09:38 PM
New Member
The possibility of the installer switching neutrals is the only reason I even tested it with my hot stick (good thing I did, or else I could have had a bad day).
However, a switched neutral wouldn't produce the double hot effect I am getting at her house.
Old 05-19-08, 07:58 AM
Received 110 Votes on 100 Posts
I'd like to see a drawing for that. All the California three way drawings I have seen still use three way switches.
Old 05-19-08, 08:10 AM
Oh, you're right. I guess it would typically use 3-way switches. Each switch sends either hot or neutral to the light. If they both send the same thing, the light is off. If they send different things, the light is on.
