Made a Boo Boo
Made a Boo Boo
I had the power company come out and mark my outside lines before digging. Made sure to take care when I got to where the lines were, but I guess not enough. While digging, my shovel scraped a wire and took off some of the insulation, about an inch on the top of the cable. the wire was not cut at all. The cable is black with a green stripe going down it.
Is this the ground and if so, am I OK? Or should I call the power company?
While diggin in another place closer to where the cables come into the house, the cables are in conduit.
A little confused here.
Thanks in advance
Thanks in advance
Received 38 Upvotes
I'm guessing that you mean an inch in length and not in thickness.
If all you did is scrape a tiny sliver of insulation then I would say that you are okay but if it is of measurable thickness then please call the power company.
maybe the telephone cable?
Although legal, it's pretty cheezy to bury unprotected cable that can't take a single shovel hit. ATT is altogether willing to do it, however, and then come by to fix it.
