fusebox question
Old 05-21-08, 03:03 PM
fusebox question
On my main box there is a serperate 100 amp box that went bad that has my dryer and stove and hot water tank hooked up to it. Can i just buy another little 100 amp box and hook it up in the same place. THANKS
Old 05-21-08, 03:09 PM
Received 42 Votes on 40 Posts
You'll have to describe the situation in more detail than that. Is the 100A panel a subpanel fed from the main panel? How did it "go bad"? Is it actually a fuse box with glass fuses or a breaker panel? Is there any way you can take a photo of the panel(s) and post a link for us to see?
Old 05-21-08, 03:28 PM
Yes the 100 amp runs off the main panel and it has four buss fuses and four glass fuses. Where the main wire hooks in to it is real loose. And i was wondering if i can replace it with a hundred amp breaker box thanks
Old 05-21-08, 05:23 PM
Are you talking about this one ??
or this one ??
Let us know.
Merci,Marc
Old 05-21-08, 05:29 PM
Yes it is something like the top one and i was going to switch it with a hundred amp breaker box if i can the old one says 100 amp wadsworth thanks
Old 05-21-08, 06:09 PM
It can be done if the the condtions met;
• SE [ service entrance cable ] must be #2 or larger
• Have meter box rated for 100 amp or more
• Have do a load demand to make sure you are ok with the exsting size you have there. [ goggle " load demand " there are few of them you can use. this is the only legal way to check the service size ]
To change over from old style fuse box to breaker box is little above the average DIY skill and yes you will have to get ahold of POCO to cut the power off when you replace the old fuse box to breaker box.
[ Keep in your mind many place will useally ask for permit anytime you replace old fuse box to breaker box ]
And when going from old fuse box to breaker box they are useally larger than old fuse box so you may not have much issue with the wires if all of them are comming above the old fuse box.
Normally if done right it will take a serious skilled DIY pretty good part of day but for Electrician it will useally a brezze useally half day or less depending on the set up.
[ I done this all the time so majorty of the time useally half day unless oddball set up.]
Merci,Marc
Old 05-21-08, 07:03 PM
i cant just unhook the wires from the main box that goes to the little box and remove the little box and put a new little box one there and run the little box of the bigger on like it is now thanks
Old 05-21-08, 07:11 PM
So,,, you are talking about a subpanel box right ?? not the main box ?
when you pull the main fuse do that subpanel box go dead also ?
if so you may want to trace back where the wire hook up there.
Merci,Marc
Old 05-21-08, 08:32 PM
yea the sub panel thanks
