Grounded outlet tester - lights all on
Old 05-22-08, 07:50 PM
T
When I test this outlet with a plug-in tester - (mine has 2 yellows and a red light), all lights are on, when a proper circuit should only light up the 2 yellows. What does this mean? Thanks
Old 05-22-08, 08:24 PM
chandler's Avatar
Received 6 Votes on 6 Posts
What does the legend say on top of the tester?
Old 05-23-08, 07:26 AM
T
The legend does not show that combination
Old 05-23-08, 08:42 AM
Received 302 Votes on 258 Posts
Defective tester maybe??
Old 05-23-08, 09:37 AM
C
For a working tester, that usually means that there are two hots, or at least a major problem.
Old 05-23-08, 09:39 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
An analog multimeter and a little knowledge on how to use it may actually be better then a plug in tester. But TJMO.
Old 05-23-08, 10:39 AM
T
Agreed - but on a board like this, I think we all sometimes wish posters would have even such a minimal amount of equipment as a plug-in tester!
Old 05-23-08, 12:29 PM
Z
Received 161 Votes on 143 Posts
My first thought is that the tester is bad. Those simple plug-in testers basically test between the 3 prongs (H-N; N-G; H-G), similar to what you would do if you had a 2-wire neon tester.
Does the tester show this result on all receptacles you plug into?
On second thought, it could be a floating (disconnected) ground . If you can, I'd try to get your hands on a simple 2-wire neon tester, that would easily resolve the question.
Old 05-28-08, 08:11 AM
T
The tester works fine on all correctly wired oulets. The problem is, this is an old house (not mine) and all I know is that there is a white, black and a "ground" coming into this box from inside the wall but I don't know if they are correct. The outlet does work. I'm going back there today and I'll check the voltage. Thanks.
