Gangable old work boxes
Received 0 Votes
I want to run two sticks of 3/4" ENT (smurf tube) into a metal old work box. One tube will be for the wiring of a 15 amp receptacle and the other for low-voltage (CAT5E, coax, etc). If I gang two boxes together, can I leave all of the sides on one of the boxes so I have a divider? Or do I need to use a separate divider?
This is the box I think I can use but I want to make sure: http://www.hubbellcatalog.com/raco/R...eet.asp?PN=565
Or could I use a double gang old work box and put a divider in it?
Received 0 Votes
Try this: http://www.hometech.com/techwire/wal...CN-B225RUPCand scroll down to the divided box.
To answer your question, the way those boxes gang together is by removing the sides and then attach the two boxes using the same screws/mounting. There's no real way to gang them together while leaving the sides (divider) in place. The closest you could get would be to mount them side by side, but the extra 1/4" or so may prevent the cover plate from fitting correctly.
Look more closely at the site. The top old work box can be used with the 65 cent divider. See the groove in the bottom of the box? And, as the others say, you can drill holes for the conduit fitting.
Received 0 Votes
Wouldn't I be violating the intended use of the box and the UL Listing?
Received 0 Votes
I'm refering to the suggestion of drilling the box
Received 0 Votes
Anyways, the idea of drilling my own holes doesn't really appeal to me and I think I've found the solution. I've been looking at the Raco "Retro-Ring" that allows you to use a standard 4" square box in an "old work" application.
http://www.hubbellcatalog.com/raco/R...&FAM=RacoBoxes
Says it's compatible with their low-voltage partitions.
Right... but I'm sure those panels are designed with the intention of being punched. A plastic box designed for a specific application is a little different.
Received 0 Votes
That is for low voltage only. You would still need a box for the regular voltage stuff. The one that rich3236 posted is a winner. Otherwise drilling the other box chandler posted is your best option. Making your own KO's is done all the time in the trade and does not violate code. Look and the pict and you can see there is a 1/2" KO on the back.
