2-Pole GFCI Breaker Question
Old 05-28-08, 07:48 AM
Here is my scenario, I ran a 12/3 romex to a Hot Tub, that needs 2 circuits, one a heater(120v, 12amps) and the pump(120v, 7amps). Is it to code to use a 2-pole GFCI breaker using the 12/3 romex or will it not work properly?
Old 05-28-08, 08:03 AM
It's okay, although probably more expensive to do it this way.
Depending on the details, code might require an insulated grounding wire, in which case Romex cable would not comply.
