no power in bathroom
Old 06-08-08, 05:17 AM
I am new and not good with electrical, please help. I took down a bathroom lights (with an outlet on the panel of lights). Replace a new lights with same outlet on the panel. I connect all three black wire together and three white wire together, and three green wire together. After installation, find out that the two wires from wall are dead. (was working before taking down the lights) I check the break, all fine. Within the same break, other lights and outlets are working also. Only these two wire in bathroom are dead. Any suggestions? Thanks million in advance.
Old 06-08-08, 07:39 AM
chandler's Avatar
Upvotes Received: 2
If you have a GFCI receptacle in another bathroom, check to see if it has tripped. Although the other lights and receptacles controlled by that breaker may work, once it enters a GFCI, all rules change. It is possible, the GFCI is even at floor level, so check really good. Let us know how that goes.
Old 06-08-08, 08:32 PM
Please tell us in what year your house was built.
