outdoor wall lights install
I will be installing 3 outdoor wall lights on the front of my garage. To run the wire from the inside, I'll need to drill a 3/8" hole SIDEWAYS through ONE of five sandwiched 2x4's, which make up a supporting beam for the garage door spans. My question is: By drilling the hole SIDEWAYS through one of the five sandwiched studs, would this not weaken the one stud since a stud's sideways thickness is only 1-1/2 inch? Does the electrical Code address this?
Also, based on some of your earlier recommendations, I'll be using a four inch "pancake" box to accommodate 2 14-gauge wires in and out. Does the Code allow two 14-gauge wires in a four inch diameter pancake box?
Any and all ideas and suggestions would be appreciated. Thanks.
Well, from looking at the two lights between the three doors on my garage, it appears that they were installed in just this manner, there's a hole drilled directly through one of the uprights in the long direction, and the building inspector didn't have a problem with that installation here.
For reference, a beam is a horizontal member, a column is vertical. If the 2x4's are nailed together, resulting in a stiffened column, then a 3/8" hole will not result in a significant weakening. Cross nailing above and below the hole will better share any tension or compression loads. Also, I would not assume all loads here are compression, especially in a earthquake or high wind area. Uplift loads are an issue where I live, for instance.
Drilling and notching - a novella
Any load bearing stud may be cut or notched <25% of its 3-1/2" "depth" (non bearing, <40%) of a single stud width.
A load bearing stud can be bored or drilled with a hole dia. <40% (<60% for non load) of the stud width.
The edge of the hole >5/8" from the stud edge, and the hole not lining up with a notch or cut.
Load bearing: if the hole is between 40% and 60% of the stud depth then that stud must be doubled, but no more than two successive studs are then doubled and bored.
