GFI breaker without test button??
Old 06-29-08, 11:50 PM
I was looking through the main breaker panel in my "new" house and noticed that all the "right" places (garage, kitchen, bathroom etc) are labeled with GFI on the door in the list describing each circuit. However, these breakers look the same as all the other ones, and don't have a test button (unless they're behind the front panel protecting the wires?).
So my question is, are these actually non-GFI breakers (that for some reason are labeled GFI), or are there GFI breakers without test buttons? Do I have to buy a GFI tester to find out?
Thanks!!
Old 06-30-08, 12:40 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Do you have GFCI receptacles? The panel wording may only refer to the type of receptacle they serve. A GFCI breaker will have a coiled white pigtail to the neutral bar.
Old 06-30-08, 12:27 PM
In some places, but I don't think they're wired to protect the rest of the receptacles. For example, there's one GFCI receptable next to the toilet, but the two non-GFCI ones above the sinks are still hot after I trip the toilet one using the test button.
Thanks, I'll check for the coiled neutral when I get a chance.
Old 06-30-08, 12:47 PM
Ray has undoubtedly identified the correct explanation. These are not GFCI breakers, but ordinary breakers on a circuit with GFCI receptacle(s).
husbus, some other GFCI probably protects the ones above the sinks.
Old 06-30-08, 01:39 PM
Received 33 Votes on 25 Posts
Or perhaps some previous owner had some appliance that was tripping the GFCI breakers and replaced them with regular breakers. If this is the case then you need to get either new GFCI breakers or else install GFCI receptacles on the "first" receptacle in these circuits.
Old 06-30-08, 08:26 PM
Yes, this seems like the most likely explanantion at this point. The previous owner did some other "strange" things.
Thanks all!
