surge protection outlet
Old 07-05-08, 04:41 AM
pugsl's Avatar
Received 76 Votes on 69 Posts
Doing some remodeling and would like to put in a surge protection outlet. would like to get rid of boxes on floor. Saw some in stores a few years ago but can not find any now, Anybody know where I might get some Thanks
Old 07-05-08, 05:24 AM
F
I like to get specialty receptacles on ebay. Hospitals are always doing renovations and they can't re-use the high quality stuff, including the surge protection ones.
Old 07-05-08, 06:24 AM
D
Surge protection devices have a limited life depending on the number and intensity of surges they have had to absorb.
I would not recommend buying this type of equipment used.
Surge protection is a multitiered application when installed properly.
For some good info:
http://www.surgeassure.com/?search=APT
Old 07-06-08, 06:42 AM
T
Received 54 Votes on 51 Posts
that's all true
For some good info:
You COULD do a test using a 600volt power supply and a series resistor, and a voltmeter. This would easily tell if the unit was completely blown and verify the clamping voltage. Even this test won't determine if all the MOV's are healthy in a parallel system.
Old 07-08-08, 08:24 PM
Z
Received 196 Votes on 176 Posts
Most electrical supply places will sell surge protection receptacles. Or do a Google search and find a retailer online.
Note though that these receptacles are comparable with probably a $15 or $20 surge power strip. For critical (expensive) loads (home theater, computer, etc), you should really still invest in a good surge protector ($50-$70), UPS ($150-$300), or some of the higher end surge/spike protectors. It all depends on how much 'insurance' you want and how much you originally paid for your equipment!
For what it's worth, here's where I bought some of mine...
http://www.smarthome.com/865131.html
