how many #12 wires allowed in 1/2 shedule 40 pvc pipe
Old 07-09-08, 06:32 PM
The wire is type thhn/thnw. (I am hoping the number is at least 6)
Anyways Thanks in advance for help!
Old 07-09-08, 07:09 PM
HotxxxxxxxOKC's Avatar
8 wires per 2008 NEC Annex C Table C-10
Old 07-09-08, 10:49 PM
You may need to derate per NEC.
8 is max as long as you meet the other criteria for conduit fill.
How many current carrying conductors?
What is the ambient temperature?
Do they pass through the attic?
Old 07-09-08, 10:59 PM
Typically with 1/2 inch PVC shed 40 8 wires{ 12 gauge THHN/THWN} is pretty much the limit for most case but if you have shed 80 PVC 90į ell or shed 80 PVC conduit then the bet is off.
Merci,Marc
Old 07-10-08, 12:39 AM
more detail.
First off thanks for replies is very helpful!
I will explain the project. I am running a 120 volt cuircuit to each of 3 sheds. The sheds are sitting next to each other, each shed is 3 feet apart. I am running a 60 amp subpanel which I will mount on the first shed. From the subpanel 3 cuircuits are being run. I will with pvc conduit enter the first shed with 3 cuircuits, one cuircuit I will hook up lights outlets a 5 amp room air conditioner in the first shed, the other 2 cuircuits I will send through the first using romex and then switching to thhn/thwn with a lb connector to go outside for about 3 feet and enter with 2 cuircuits into the 2nd shed. 1 cuircuit I will use for lights/receptales in 2nd shed and travel with 1 ciurcuit to the third shed.
whew.. Its the connection with 2 cuircuits from shed 1 to shed 2 that I am asking about..
2 black hot wires, 2 neutral, 2 ground. so I guess 4 carrying conductors..all running 120
Well its southern Ca, inside a shed and then outside the shed for about 3 feet then back inside the shed. so hmm could be 90 degrees-100 the hottest I guess.
no
Thanks for replies let me know if you think it is legal!
hope this clarifys..
Old 07-10-08, 09:26 AM
Received 42 Votes on 40 Posts
Yes, it sounds okay to me.
