10 amp breaker to 15 amp
Old 07-21-08, 08:52 AM
Silly Question:
I've got several 10 amp breakers in my fuse box and I was told that I should change them to 15 amp breakers, this would avoid some of the flickering I get when multiple devices are running at the same time, most of the breakers are for outlets and lights.
Will this really make a difference? I know it's just a matter of shutting off the main and popping the existing 10 amp breakers out and replacing them with 15 amps; but, I'm not really sure if this would be cost justified to replace eight 10 amp breakers in my house.
Thanks
Old 07-21-08, 09:00 AM
You can never, ever, ever simply change breakers to a larger size without first verifying if your circuit wiring can handle it. And 99% of the time it cannot. Violate this rule and you risk burning your house down.
Have you really got 10-amp breakers (10-amp breakers are incredibly rare)? Do you have breakers or fuses (you mentioned a "fuse box)?
Furthermore, a larger breaker wouldn't help a flickering problem anyway. The flickering is due to the wiring, not the breaker.
Old 07-21-08, 03:58 PM
Where do you live? In the US, 10A breakers are rare. If you're elsewhere in the world, let us know, there are a couple here who are knowledgeable about other countries' power systems.
