need help installing a switch
Old 07-21-08, 08:10 PM
I am trying to install a new light switch to an existing light, actually two lights. How do you connect the switch to the lights. I was told to put black with white and white with black when it came to switches. I am obviously doing something wrong because that does not work. I was told this would be easy, I need HELP!!
Old 07-21-08, 09:01 PM
So, i'm confused.Are you trying to replace an old swich or wireing a new swich?
Old 07-21-08, 09:48 PM
I can only guess what you have there.
There are two colors associated with the power handling to a device. Black and white. Black is the hot lead and white the return or neutral.
Depending on what you have it could be....
Black and white enter box feeding power. Another cable enters box. The two whites are connected together with a wire nut. One black goes to one terminal of the switch, the other black goes to the other terminal. If you had an additional light cable in the box, its white would connect with all the others as above and the black would attach to the switch screw terminal where the black to the other light attached.
This may or may bot be what you have. If not describe exactly what you are looking at in your box.
Old 07-22-08, 07:36 AM
Received 3 Votes on 3 Posts
Light Switch
There are two possible situations:
1) The power wire feeding the light circuit is routed to the switch box.
or
2) The power wire for the light circuit is routed to the ceiling box where the light fixture is located.
Which do you have? How many cables in the switch box?
