Pulling power from a middle of the run outlet
Old 07-22-08, 12:27 PM
I am installing under cabinet lighting in the kitchen and need to provide power to it. I would like to pull the power from one of the outlets; the problem is all the outlets are middle-of-the run.
I would like to know if it is possible to pull power from an outlet that is middle-of-the run and not affect anything else on that circuit.
If possible how would I do the wiring? Currently there is 1 black, 1 white, and 1 bare incoming wires and 1 black, 1 white, and 1 bare outgoing wires.
The ultimate goal is to provide power to the dimmer, which provides power to the under cabinet lights.
I live in Fairfax county, VA
Thanks in advance for all your help
Last edited by terpsarlington; 07-22-08 at 12:29 PM. Reason: add location information
Old 07-22-08, 12:44 PM
pcboss's Avatar
Received 24 Votes on 20 Posts
The wiring to the receptacles in kitchens and dining rooms cannot serve lighting loads.
You will need to find another source of power for your undercabinet lighting.
Old 07-22-08, 01:47 PM
I saw some under cabinet lights which are plugin, can the receptacles in the kitchen serve these lights?
Old 07-22-08, 01:51 PM
Received 42 Votes on 40 Posts
Yes, you can use plug-in lights on the small-appliance branch circuits.
