cutting ceramic tile for outlets
Old 07-31-08, 06:56 AM
Anyone have any ideas on how to cut into an existing tile backsplash to cut in some outlet boxes?
Old 07-31-08, 08:06 AM
Received 42 Votes on 40 Posts
A carbide tile bit in a Dremel tool.
Old 07-31-08, 08:43 AM
Yeah I do the same but I use a Roto Zip with a tile cutting bit.
The Dremel or roto zip will give you the best clean cuts with tile still on wall.
Whichever you use, start the bit at a 45 degree angle until you get through the tile and then cut the rest out.
These templates are also handy but you don't have to use them to get good cuts
http://www.cutzout.com/SingleGangIns...nTemplate.html
Old 07-31-08, 08:56 AM
I also use a RotoZip with a tile cutting bit. It's like a knife through butter on wall tile, but it doesn't as well work on the much harder floor tile.
Old 07-31-08, 07:22 PM
wgc
wgc is offline
if 4" tile, can just remove it
Depending on your requirements and the size of the tile, don't forget the option of removing a whole tile.
I recently tried both options:
- One counter had a nearby receptacle that I had to line up with, so I borrowed a rotary tool to cut the tile in the exact spot.
- Another counter did not have any nearby outlets and the backsplash tiles were slightly over 4", so I removed the whole tile and inserted a double-gang box.
Removing the tile just required a cheap grout knife, prying tools, and a lot of patience.
