Q about washroom light
Received 0 Votes
Received 0 Votes
I am not sure what you mean by washroom, but assume you are implying the bathroom. At any rate, you can have any fixture you desire in the bathroom unless it is "IN" the shower or any like enviroments. If they are going to get wet like over the shower, then they must be a sealed fixture rated for wet location.
Received 0 Votes
Need more infomation on what type of luminaire in the bathroom it will really can change a bit.
Normally the wet rated luminaries are used in the shower { and useally yes they will required GFCI for this one }
But for any other type of lumiaires it will depending on the set up of the bathroom if have bathtub in there or not.
Merci,Marc
Merci,Marc
Received 0 Votes
Sorry I meant bathroom, my concern is with humedity. Yes there is a bathtub and the liminaire is located on a wall above the cabinet and sink about 40'' from the bathtub.Existing luminaire is wired downstream of GFI
Tnx
Tnx
Received 0 Votes
You should be ok as long the luminaire is away from bathtub but just wondering how big the bathroom is ??
Normally I useally keep it at least 3 feet away from " edge " of bathtub.
Merci,Marc
Merci,Marc
Received 0 Votes
Bon jour Marc mercy pour la reponde ,the bathroom is really small and there is no more than 40 inches from the luminaire to the edge of the bathtub but water is not likely to get there my concern is the metal in the luminaire corroding with the humidity and compromising the electrical components but this is just me......
