i need a 220v extension for an window AC
Old 08-02-08, 01:09 PM
about 28,000btu. can i get a 50 foot #10-2/g in a stranded copper and not deal with the romex solid copper? i will install the two connectors for the ends to match my plugs.
thanks in advance......
Old 08-02-08, 01:59 PM
Buy some 10-3 sjo wire... You cant make extension cords out of NM anyways...
Old 08-02-08, 03:31 PM
10/3 sjo wire...does home depot/lowes have this?
or, what is the local source in texas? thanks
Old 08-02-08, 05:48 PM
the stock at home depot/lowes varies by location, they should have it but I would call first. If not a local electric supply would be your best bet.
Also remember that SJ cord and Romex wire numbers are not the same. Meaning
10- 3 SJ = Black, White, Ground
10- 3 Romex = Black ,white, red, ground
So if you need a Red, ask for 10-4 SJO cord
Old 08-02-08, 06:15 PM
Probably but if they don't, any electrical supply house should.
Old 08-02-08, 07:47 PM
got the sjo wire at HD..thanks for the help.
will put on the ends tomorrow and fire up the AC.
Old 08-02-08, 10:52 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Extension cords are intended for temporary use only. You will need to install a permanent receptacle. What are the specs for the receptacle (amps/number of wires) you are plugging into? It was intended for an AC wasn't it?
Old 08-03-08, 09:20 AM
chandler's Avatar
Received 3 Votes on 3 Posts
You definitely don't want to run a 50' extension cord for an air conditioner. Hard wire it correctly to the location. It is the only way to do it safely.
Old 08-03-08, 09:19 PM
...against the recommendations of those who are concerned about code violations and safety...
please see the latest comments on your other post
willis
Old 08-04-08, 10:07 AM
Received 42 Votes on 40 Posts
I merged your threads into one because they cover the same problem.
A 28kBTU air conditioner is a pretty big unit, especially to run at a distance of 50'. Without knowing the nameplate specs of the unit, I'm not sure the #10 SJO is sufficient for this A/C.
Furthermore, 50' is a long cord to use safely. Make sure it is not covered by any carpets or rugs, and that it does not present a tripping hazard such as crossing a doorway or hallway.
Old 08-05-08, 08:27 PM
A 28K btu A/C @ 240 volts will draw anywhere from 24 to 28 amp very easy and with 50 foot extenison cord that part I am not too crazy but it can be done but my main conderastion is the amout of current going thru the 10-3 SJO cord.
Is there any reason why can't you run a new romex cable for the A/C unit ??
Merci,Marc
