start capacitor
Old 08-05-08, 07:01 AM
A
start capacitor
The pump motor for my pool filter hums when I try to start it. I know it's probably the start capacitor. I've done some work with electronics before but never done anything with single phase motors. The motor is 115/230V 1.5hp and has a 3 terminal start capacitor. Two yellow wires and a red one. Is there any order to removing the wires since it might be charged? Also I read somewhere they should be discharged before removing. thanks
Old 08-05-08, 07:13 AM
D
Make sure ALL power is definitely off. Short the leads of the capacitor together - all leads - but it is unlikely there will be any charge. I assume you are replacing the capacitor?
You said 115/220. It is either wired for one or the other. Also the rotor cold be locked up for another reason, like a bad bearing but this would likely blow the breaker fairly fast.
Old 08-05-08, 07:22 AM
A
Nothings locked up. Spins freely. I can get it to start if I keep flipping the switch which leads me to believe it's the capacitor. Like I said, I never worked with large capacitors before so I want to be careful not to short anything or get zapped.
Old 08-05-08, 11:45 AM
A
Removed and tested capacitor. It's bad. I'm curious. Why aren't the terminals of these start capacitors labeled positive and negative? Does it matter which wire goes on what terminal?
Old 08-05-08, 12:34 PM
D
No it does not matter. AC motor start capacitors have no polarity as AC has no polarity.
Old 08-05-08, 12:48 PM
A
Ah. Makes sense. Installed new capacitor. Back up and running. Thanks
