GFI Breaker
Old 08-06-08, 04:14 PM
GFI Breaker
iam hooking up a hot tub, but the tub is 240 volt with no neutral will the breaker still work? thanks to any repleys..
Old 08-06-08, 04:59 PM
Yes. Even though you have no circuit neutral to attach to the breaker, still attach the white pigtail to the neutral bus in the panel.
Old 08-06-08, 05:00 PM
Yes, the breaker will work with no load neutral, but you still must connect the supply neutral pigtail to your neutral bar.
Old 08-06-08, 06:21 PM
Thank-you very much for your reply's..
