subpanel bonding???
Old 08-09-08, 04:08 AM
subpanel bonding???
good morning, I'm installing a subpanel today, problem is this, my main panel is the type with shared neutral/ground bar. should i bond the subpanel once installed? my guess is yes but thats why i'm asking the professionals because i want to do it right.
Old 08-09-08, 05:18 AM
Bond the subpanel to ground, but not to neutral. Need a 4 conductor feeder for sub, 2 hot, 1 neutral and ground. Neutral and ground are seperated in the sub, neutral is isolated, and ground is bonded to can.
Old 08-09-08, 06:55 AM
Received 42 Votes on 40 Posts
The neutral and ground are connected only in the main panel. You run a four-wire feeder to the subpanel (black,red,white,bare). At the subpanel the neutral and ground bars are isolated. This may require you to purchase an add-on ground bar kit for the subpanel and to remove the bonding screw and jumper from the neutral bus. The ground bar is connected to the subpanel box with machine screws; the neutral bus should be isolated from the box with plastic spacers or mounts (provided with panel).
