Lost half My Service.
Old 08-10-08, 04:22 PM
Hello all;
I have lost 240v service to my home. Home is 50 years old and has a fuse box.
Took some measurements at the panel where the Main comes into the house. I got three wires. Two black and a white.
Across two blacks=120v
Across one black and white=120v
Across Other black and white=0v
I have continuity across the two main 100 amp fuses and replaced the two smaller 35 amp fuses.
Was thinking I should be getting 240v across the two Blacks.
I'm so confused; can someone enlighten me?
thanks
wook
Old 08-10-08, 04:26 PM
call the power company, you lost a leg. ....................................
Old 08-10-08, 04:27 PM
HotxxxxxxxOKC's Avatar
Call the power company. This is probably a problem between the pole and your meter.
Chris is a faster typer then I.
Call them now, they are sitting there drinking coffee waiting for you.,....
I would also pull any fuses for 240v appliances.
Old 08-10-08, 05:10 PM
Thanks Guys. Thats what I figured.
There on the way.
Old 08-10-08, 07:15 PM
If you took your voltage measurements at the bottom of the main fuses and one of them was "open", your voltage measurements could very well be exactly what you are reading. But I'm sure you too them of the top of the fuses, right???
Old 08-10-08, 09:05 PM
Yep. Corroded connections at the top of the stack. Its all good now.
Old 08-10-08, 09:34 PM
Your lucky is was not the grounded conductor ( aka, neutral)
