wiring for welding
Old 08-27-08, 01:26 PM
Roeboat109's Avatar
wiring for welding
what type wiring would i need in my garage to be able to do some welding .all i have right now is 12-2 wg. Its just run off a fuse box from a line underground from the house. My son is taking welding classes.
Old 08-27-08, 01:41 PM
Received 170 Votes on 151 Posts
What kind of welder do you expect to get?
I have a 110 arc welder that runs off of a 20 amp circuit [what you have] and I think there are some wire welders that also run off of 20 amp 110. I also have a 220 stick welder that is on a 50 amp circuit with #8 wire.
Old 08-27-08, 01:42 PM
Received 42 Votes on 40 Posts
It depends entirely on the size and type of the welder.
This is almost certainly have to be upgraded to support anything but the smallest buzz box welders.
Old 08-27-08, 02:42 PM
When doing wiring for welders, just follow the manufacturer's instructions. It will tell you what size breaker and what size wire to use. The calculations are complicated, and the manufacturer has already done them for you, so just use them.
