Gfci
Old 08-30-08, 08:13 AM
B
Gfci
Does anyone know of a manufacturer who makes a GFCI receptacle that is a little smaller in physical size than the normal one you find in the big box stores?They are so hard to squeeze into a shallow box in a tight area
Old 08-30-08, 10:39 AM
F
AFAIK .,, most of the GFCI repectale they are pretty much standarized not too much differnce on sizewise at all
Is your receptale box is too small ? if so you can either change to deeper box or go with two gang box.
What circuit is this receptale you are replaceing ?? somecase it will be easier to get a GFCI breaker.
Merci,Marc
Old 08-30-08, 12:07 PM
Perhaps you can find at the big store an extension that can attach to your current outlet box to increase it's volume. They're available in metal, not sure about plastic. It would perhaps not be asthetically pleasing to you??
