replace 33w transformer
Old 09-02-08, 09:28 PM
I have a 33w transformer that runs my sprinkler system controller. I have used the bottom plug, however I am unable to use the top plug for a regrigerator because the plug cord comes straight down from the plug into the transformer. Can I replace the transformer with a different style that is not as large? Or do they make a outlet where the grounds are at opposite ends to accomodate plugs going in opposite directions?
Old 09-02-08, 11:23 PM
They sell short (less than 1 foot) extension cords that you plug the transformer in to and then the extension with a normal plug into the wall.
Check here -
http://www.radioshack.com/product/in...entPage=search
Old 09-03-08, 07:33 PM
Received 19 Votes on 18 Posts
I haven't used one myself, but they sell rotating outlets:
http://www.acehardware.com/product/i...ductId=2871202
with a bit of wiremold or a remodel box, you could add a second duplex receptacle a couple inches away. If you want more details, ask - someone will certainly be able to help!
Old 09-04-08, 05:43 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Or replace the single gang box with a double gang box and a second duplex receptacle. A bit of patience usually easy enough to get the old box out and enlarge the opening for a double gang old work box. If needed you could even align one receptacle ground down and one ground up.
Old 09-06-08, 08:14 AM
Thank you to all for your advise. I have wired junction boxes before. Double gang box sounds like the way to go.
Thanks again.
