New Wall Oven
Old 09-04-08, 08:22 AM
New Wall Oven
I have a new GE wall oven to install. The wiring from the oven appears to be about 12 ga...never seen that before on 240v. It recommends the j box to be installed 24" above the bottom of the unit, in which case I would have to extend the house wiring and add another box. Any idea about the height of the box, and if I extend the house wiring, should I stay with the 6 ga thats there or match the wiring on the oven?
Old 09-04-08, 08:53 AM
If the wiring coming from the oven is part of the original package (I assume this is a new oven) then it is OK to use it. It should be in a metal sheath???? Where you put the connection box outside of the oven should be personal preference. They would recommend a location for rough-in but I see no reason why you can't put it where it reaches. Using different wire sizes is fine so long as you use the breaker size recommended for the oven. I would say the wire coming out is probably #10 which would be a 30A breaker but check the manual.
Old 09-04-08, 09:33 AM
Received 42 Votes on 40 Posts
Recommends or requires? Perhaps the reason is due to the shape of the back of the oven? Some have divots and grooves to accommodate the junction box behind. The placement of the junction box should not be a big deal unless the oven won't fit in the hole.
Match the house wiring. What size breaker does the oven require?
Old 09-04-08, 10:08 AM
Received 15 Votes on 15 Posts
my oven had a similar story
The instructions called for a J box high in the oven cavity. In my case, the existing J box was 3' lower than that, it was even below the oven hole altogether in a lower cabinet. The conduit reached my existing J box OK. Like yours, the oven supplied conductors were 12AWG, but they were a high temp insulation.
