Knob and tube wiring
Old 09-04-08, 10:23 AM
msullivan02's Avatar
Quick question: I have some K&T wiring in my home, but in some places it lacks the tube that goes through the joist. I do plan on replacing but can't afford it presently. Do I have a serious problem with the wire going through the joist without the tube? Or do you think it will be okay for now?
Old 09-04-08, 10:53 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
If the joist is dry wood it should be ok. Replacing the entire run to the box would probably be the only code acceptable fix. Does the insulation look OK? Just touching the insulation could damage it so I'd just leave it as is if it looks ok.
Old 09-04-08, 03:18 PM
Received 33 Votes on 25 Posts
It's not correct but it has probably been that way for at least fifty years so as long as no additional loads are placed on the circuit I would agree with Ray to not touch it and just replace as soon as you can afford to.
Old 09-05-08, 11:16 PM
thanks guys, I think I'll just leave it alone for now the insulation does look pretty brittle though but I don't plan on touching it until I'm ready to replace it.
Old 09-08-08, 10:15 AM
Received 42 Votes on 40 Posts
That's the best policy with K&T. Don't touch it until you're ripping it out to recycle the copper.
