Reload this Page >
Minimum distance between laundry tub and washer power outlet
Old 09-06-08, 07:13 AM
Hi there,
I'm in the process of framing my basement and I'm working in the laundry room. I've moved my laundry tub ~8" to the right and I'm going to re-plumb the water faucet and washer supply values today but I was wondering if there's a required minimum distance between your laundry faucet (or water in general) and the washer power outlet? After I relocate the laundry tub the power outlet is about 9" to the right and 9" above the faucet. Hopefully someone can help! Thanks
Old 09-06-08, 08:49 AM
210.52(F) says at least one receptacle outlet shall be installed for the laundry equipment.
210.11(C)(2) says it shall have no other outlets.
210.8(A)(7) says where the receptacle is installed within 1.8 m (6 ft) of the outside edge of the sink needs to be GFCI protected with a GFCI outlet or breaker.
I'm almost positive there are no exceptions to that last rule, even with a washer receptacle. If there is, I can't find it. Sometimes a washer will trip a GFCI when it first starts up. If that's the case, you could switch it out with a regular receptacle.
Maybe someone else can comment on that last bit. If you want to avoid it entirely, then make sure your washer outlet is atleast 6 feet away from the sink and then use a regular outlet.
If your using emt or ent with metal boxes attached to the concrete wall, then make sure the boxes are grounded as well.
Old 09-06-08, 09:16 AM
thanks MadPenguin!! I'm assuming the same would be true for a dryer receptacle?
Old 09-06-08, 09:28 AM
pcboss's Avatar
Received 87 Votes on 74 Posts
Since you are in Canada I am not sure of the CEC requirements. In the US only the 120 volt receptacles require the GFI protection.
I will also disagree with MP about replacing the GFI with a regular receptacle if the washer trips the GFI. There is no exception.
Old 09-06-08, 09:37 AM
Well, I wasn't sure about that which is why I asked for further input. I said you "could", not that you "should". Like I said, best to make sure your washer outlet is at least 6 feet away so your washer runs without tripping and you don't get electrocuted.
The only requirement for a dryer, that I'm aware of, is to make sure the frame is grounded with it's own grounding conductor. I've never seen a GFCI 30 amp dryer outlet nor have I ever seen a dryer with GFCI protection of any kind.
If you keep your washer outlet 6 feet away, then depending on the way your appliance doors open, put your dryer on the other side so it's 8-9 feet away from an exposed water source.
