Blown fuse is hot to the touch
Old 09-07-08, 07:05 PM
A fuse blew in our panel tonight - nothing was different. It did blow the outlet that our dehumidifier was plugged into, but we have used it many times before in that spot.
Concern was that the 15 amp mini breaker that blew was hot to the touch. Replacement one we put in seems to be warm now as well?
Is this a concern?
Old 09-07-08, 08:01 PM
Cool
Did you inspect the condition of the bus-bars during the replacement procedure of the new C/B? Had one recently that had stucco paint all over all the tabs. The quad C/B was burnt to crispy critters. The plastic insulators were also charred badly. The panel will have to be replaced. This info may or may not apply to your situation. I would definitely take a peek at the tab the C/B sits on. Be carefull working around panels. As a minimal safety precaution I always wear a pair of good leather gloves when working in a panel.
Old 09-07-08, 09:39 PM
Also check that circuit. Why did it trip? It sounds like you might have an overload condition. Breakers do not have a quick trip at just over their current limit. In other words a 15A breaker would not trip for a considerable time with 16A being drawn but it wold eventually. In the process it would get quite warm. I would not say hot but then that is subjective.
Old 09-08-08, 06:52 PM
i would get rid of the mini breaker and put a 15 amp fuse back in. In my own experiences the mini breakers simply never trip but physically destroy themselves. Either by being so hot for so long they become brittle, to litterly grenading in the panel.
gl
nova_gh
master electrician
Old 09-09-08, 07:31 AM
What is the amp rating on the humidifier? And do you plug in/unplug this thing a lot, in that one particular outlet? And do you have copper or aluminum wire?
