Power strip in kitchen cabinets?
Old 09-10-08, 08:53 AM
Hi all,
I'm working on a wall unit for our kitchen. It's on the opposite wall from the sink, about 12' away from any water sources. It consists of three cabinets, and each cabinet has three sections-- lower and upper sections have doors, middle section is open.
My wife would like to have our counter-top microwave and our bread machine tucked into a couple of the open middle sections, and I don't want to tear up the walls to install permanent wiring. Currently both of these machines are plugged into a nearby outlet. So I'm wondering about installing a high amp power strip in the cabinet and simply plugging it into the outlet that currently supports these machines. A small hole in the back of the cabinets would allow for running the cords to the strip.
Any comments on the feasibility of this?
Thanks,
Tom
Old 09-10-08, 10:39 AM
As much as you may hate it, you should install proper permanent recepticals, one in each bay, perhaps with the microwave on one circuit.
Old 09-10-08, 10:42 AM
Thanks. I was afraid so. Anybody else out there have a different opinion?
Old 09-10-08, 11:20 AM
Received 42 Votes on 40 Posts
You can use wiremold surface mounted raceway products which are listed as premises wiring. They have a number of items which are like power strips available in many colors of plastic and metal. Most of the big box stores carry a reasonable selection of pieces. A supply house could special order any additional parts.
Old 09-10-08, 11:53 AM
Installing Wiremold
Thanks for that answer, ibpooks.
I just looked up Wiremold products on the Internet. Just what I'm looking for! One question -- do you know the amp rating of the plugmold "self-contained" multi-outlet strips?
Old 09-10-08, 01:26 PM
Sorry I do not know. My guess is that it would be a minimum of 12A (1440W), but probably 15A (1800W).
Old 09-10-08, 01:29 PM
Thanks
Hi again,
I appreciate your help on this. I think the project will work just fine.
Old 09-10-08, 02:29 PM
Let me add this comment on the OP's situation .,,
However If you are aware about the NEC code reqired all the kitchen countertop circuits are reqired a GFCI protection.
That in USA the Canada little different it will reqired GFCI 2 metre from edge of sink unless stated in their local codes.
Merci,Marc
