Switch Wiring
Old 09-12-08, 03:44 PM
Switch Wiring
I'd like to add a switch to control some under cabinet lights. The box only has a 3 way switch in it right now and no other wires (other than to the under cabinet lights). None of the leads stay hot. Is there some way to safely wire this new switch up without having to run another cable into the box?
Old 09-12-08, 03:53 PM
Tolyn Ironhand's Avatar
Received 55 Votes on 48 Posts
If the 3 way does not have a wire that is hot all the time (or a neutral) then no, you can not do it. You will need another cable.
Old 09-12-08, 04:23 PM
None of the wires is hot all of the time, unfortunately.
Old 09-12-08, 05:02 PM
Then your going to need another hot and neutral.
