Doorbell transformer positioning?
Old 09-23-08, 05:39 PM
JoeTheZombie's Avatar
Where does one normally locate that doorbell transformer? Right now, it is attached to an outlet box hanging on a basement joist. However, this is going to be living space soon and it needs to go. Where is the question.
Old 09-23-08, 05:50 PM
chandler's Avatar
Received 5 Votes on 5 Posts
Most doorbell transformers will fit into a deep round box, and are sometimes even covered by the doorbell itself. If you put it in a round box, it has to remain exposed with a coverplate.
Old 09-23-08, 06:33 PM
W
I put mine on a 4 square box in the attic right next to the access door. I have also seen them attached to the breaker panel. Most doorbell transformers are made to be mounted thru a 1/2 inch knockout in a panel/junction box.
Old 09-23-08, 07:18 PM
Z
Received 107 Votes on 99 Posts
I'd just relocate it to somewhere that's accessible. Could be the attic, crawlspace, unfinished basement, garage. If worse comes to worse, it could be put behind a 6"x6" access panel inside a wall.
The transformer does produce heat, so I wouldn't bury it in insulation or anything like that.
Old 09-23-08, 08:03 PM
F
Bah, put it on it's on 50amp circuit.
Um, don't actually do that. Virtually anyplace is good. I've seen them on main panels as well.
Old 09-24-08, 07:09 AM
Thanks guys. I didn't know if it had to be in a specific place or not. Looks like the attic is a new home for her.
