Fan and Dimmer Switch
Old 09-25-08, 09:17 AM
Received 1 Vote on 1 Post
Question Fan and Dimmer Switch
This is more of an electrical question than a heat a/c one so I am posting it here. I am trying to balance my HVAC system in an old cape. The ducting is poorly set up for upstairs so I have installed axillary in-line duct fans in the 3 trunks that feed upstairs. I now have better air flow but it is not balanced. Can I use regular light dimer switches to reduce the speed of the auxiliary fans in proportion to balance the output air flow?
Thanks, Beer 4U2
Doug
What can go wrong in my house ~ does
Old 09-25-08, 09:34 AM
Received 42 Votes on 40 Posts
Not very well no. The likely outcome is that it will ruin the dimmer, the motor or the motor will buzz obnoxiously.
Old 09-25-08, 10:35 AM
Question
Any suggestions in enexpensively reducing the fan speed in order to balance the system. I went from no airflow upstairs to it now being off balance.
Thanks for the advice. Beer 4U2
Doug
What can go wrong at my house ~ DOES!
Old 09-25-08, 12:30 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
You could try dampers in the duct work.
