nm-B 6/3 in conduit
Old 09-26-08, 08:01 PM
V
nm-B 6/3 in conduit
I ran NM-B 6/3 cable through 3/4" metal conduit for about 10ft. from my main panel to a subpanel. I did it to protect the cable that will be exposed in my workroom, but after doing some research I am concerned this will be a problem. Any suggestions, or will is this not be a problem? Thanks.
Old 09-26-08, 09:13 PM
B
Since you are panel to panel you have a complete conduit run. 6/3 with ground would be a violation of conduit fill requirements in 3/4 metal conduit either emt or rigid metal conduit (I didn't check the other types). You need 1" sorry but I don't know what else to say....
If you like I can post the calculation that would require 1 inch metal conduit.
Old 09-26-08, 09:22 PM
F
The only legit way for #6's in the inch conduit is run THHN/THWN conductor.
If you keep the NM in the conduit you must increase to 1 inch conduit size there is no other way with it.
Merci,Marc
Old 09-27-08, 04:56 AM
V
Thanks gang! I appreciate the input. I'll switch it out to 1" conduit.
