Dayton Farm Duty Motor 1TMY4
Old 09-27-08, 08:06 PM
U
Here is the wiring diagram on the motor itself.
I want to wire a motor to low voltage power.
Here is the wiring diagram on the motor...
What does this mean..what do I do with the
Line 1
P1
Line 2
White
Yellow
Black
Blue
T1
P2
Orange
Red
Then I have the power cord with a
Black
White and
Ground
I do not know how to connect this correctly?
Any ideas?
Old 09-27-08, 08:34 PM
F
C'est simple .,,
But let me get the colour match up with the numbers then we will go from there ok .,,
1 - Bleu
2 - White
3 - Orange
4 - Yellow
5 - Black
6 - NCA [ No Colour Assigned ]
7 - NCA
8 - Red
P1 - NCA
P2 - Brown
Now here is the connection follow my chart and double check the # 6 and 7 it will stamped so you will find that numbers ditto on P1
I will show the connection for CCW rotation { for reverse connection see below }
L1 - 1,3,6,8
L2 - 2,4,5,7
Note the P1 will useally wired to L1 and motor leads { it will be in series }
to change the rotation here the connection
L1 - 1,3,5,7
L2 - 2,4,6,8
That should be correct for 120 volt hook up but if you have 240 volt hook up or 240 v circuit stop right here and let me know asap i will give you other chart if need to be.
Merci,Marc
