testing live wires caused big spark
Old 09-28-08, 01:23 PM
I have a light fixture thats gone dead. I thougt I could use a voltage tester..(a red and black wire with a red light) and touch the leads on the switch. Assuming it would light up ....my wife was going to run thru the circuit breakers until the light when off. I touch the probe to both leads and got a big spark and a scare.
What is the correct way to test if the line is still live if you don't want to turn off the main to the whole place.
Old 09-28-08, 03:10 PM
You test from 1 screw at a time to ground or metal of the box (if it is metal)
You got a spark because you completed the circuit with your tester.
Good news is, since you got a spark you have power there.
More than likely the fixture/fixture socket is bad
Easiest way to test this is to shut switch off, take fixture down and put tester across black and white leads. Have a helper turn switch on for a second. If tester lights up you have power
Old 09-28-08, 04:37 PM
that makes sense...did i fry my tester? and how come I won't get the same scary reaction when I connect the black and white wire of the fixture?
Old 09-28-08, 04:55 PM
[QUOTE=rich3236;1437519]You test from 1 screw at a time to ground or metal of the box (if it is metal)
Easiest way to test this is to shut switch off, take fixture down and put tester across black and white leads. Have a helper turn switch on for a second. If tester lights up you have power[that makes sense...did i fry my tester? and how come I won't get the same scary reaction when I connect the black and white wire of the fixture?
/QUOTE]
Old 09-29-08, 08:24 PM
The spark won't happen again if you test the wires at the fixture, because you are not using your tester to make the circuit.
Take fixture down, and test the 2 wires that went to the fixture ( usually black and white)
check your tester on a known working outlet somewhere to make sure it still works
