Help Please
Old 10-01-08, 02:40 PM
Help Please
Hi guys
its bin a long time and I cant remember the RULE of electrial.
I have a heater I want to install in my garage. the spec plate
on the heater says (volts AC / 60 HZ / 480) 10 / Kilowatts
Phase 3 (Motor - VAC / 480 AMP / .22 Controls VAC / 24)
I have 200 AMP sevice or the maine braker says 150. do I need
to run a 120 service or 220 I know this sounds stupid but I forgot how to determen the phase.
T.I.A
Joe M
Old 10-01-08, 02:46 PM
Do you have 480 VAC 3 phase available in your garage? If the answer is no, then you can't use the heater unless you buy a 3phase converter.
Old 10-01-08, 03:22 PM
Received 42 Votes on 40 Posts
480V three-phase is only available in large commercial buildings. The heater won't work on your single-phase residential service.
Old 10-02-08, 07:26 AM
Hey thinman thanks very much for the help. I diden't thimk I could use the heater when I saw 480V, but I was not shore.
I guess I'll give it back. thanks again.....
