How to wire a pilot switch
Old 10-06-08, 01:04 PM
D
I am trying to figure out how to wire a pilot switch for the cellar light, but am at a loss. I guess I assumed that it would get wired like any light single-pole light switch, but now that I have it in hand, I see I was wrong. Rather than two brass screws, as I expected, the switch's terminal configuration looks just like a three-way.
The light switch I want to put it on is wired with a switch loop.
Thanks, in advance
Old 10-06-08, 01:59 PM
W
Received 21 Votes on 20 Posts
Switch
Check the instructions. I believe the third screw is to connect a neutral wire. Sounds like you will need to add a neutral from the switch to the light fixture. Good luck with your project.
Old 10-06-08, 07:43 PM
TomZ1's Avatar
Yup.
Need a neutral for a pilot switch...switch loop won't work.
Found that one out the hard way...
Old 10-06-08, 08:21 PM
F
If you want pilot light on your switch location you have to bring the netural or rewired that one to either 14-3 or 12-3 depending on the conductor size.
the white one is used for netural conductor while the black is hot conductor and red is switched conductor and that is pretty common with this set up.
Merci,Marc
Old 10-07-08, 11:19 AM
D
Thanks everybody. I have a length of 14/3 that I can use. It is a really short, easy run to rewire.
Old 10-07-08, 11:39 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
The breaker is 15 amp isn't it?
