GFCI problem
I'd like to ask a follow up question. I also have a situation that my GFI receptacle trips often and before I replace it I want to make sure if the receptacle is the problem. It feeds the light for shed via underground conduit. So, I need check for only loose connections for branch circuits? Any other suggestions? How do I check if the GFI is defective?
GFCIs to have a tendency to go bad after awhile.
Good Luck!
