kitchen wiring
Old 10-15-08, 12:56 PM
R
kitchen wiring
hello.
i have gutted my kitchen and I am replacing all wiring. I am planning on wiring it this way with 12/2. Am i correct or is there a better way to combine some of this??
dishwasher/grbage disposal/gd switch - dedicated 20 amp circuit
6 countertop gfi outlets- 20 amp circuit
above stove(gas) microwave w/exhaust fan and under cabinet lights (xenon) - 15 amp circuit (or 20amp?)
ceiling fan/light/switch and two can lights/switch above sink - 15 amp circuit
refigerator/2 wall outlets/ patio lights on 20 amp circuit
thanks, rick
Old 10-15-08, 01:30 PM
I
Received 43 Votes on 41 Posts
Okay.
This should be on two 20A circuits per code. It doesn't have to be three and three, but you do need two 20A circuits serving the coutertop receptacles. One of these receptacles can be behind the range for the clock/sparker.
The microwave should be on a dedicated 20A circuit. Put the cabinet lights on with the other kitchen lighting; this circuit can be 15A so long as the max wattages of the light fixtures add up to 1800W or less.
What are the receptacles used for? If you plugged in a vacuum cleaner for example, it could trip off the breaker and lose a fridge full of food. I like to keep the fridge on dedicated.
