main panel for garage
Old 10-21-08, 05:46 AM
I built a detached garage not sure what amp panel and size wire. The run is about 45' and its a residential garage nothing crazy. I have a small compressor and welder and 220v heater along with basic lighting and receptacles. Im thinking 60 amp would be fine. Any suggestions?
Old 10-21-08, 07:50 AM
Depends on the specs of the welder and the wattage of the heater. Details are everything.
Old 10-21-08, 09:39 AM
The heater is 5000 watt 23 amp and the welder is a small 110 lincoln welder
Old 10-21-08, 11:46 AM
T
Is there a nameplate on your welder? Is it a TIG, stick welder? It should list the welder's input amps.
http://www.mylincolnelectric.com/Catalog/equipmentseries.aspx?browse=101|129|
http://www.mylincolnelectric.com/Catalog/equipmentseries.aspx?browse=101|207|
