Changing backstab outlet to side screw
Old 11-07-08, 08:50 AM
I am in the process of changing my outlets out in my house and I've come across an outlet that is back stabbed.
I have already bought a new outlet that has the side screws only...
The issue I am having is that there are only two wires (one black and one white) coming out of the wall into the socket.
If there are 4 screws in the new outlet, and only two wires, how should I install it?
Thanks!
Old 11-07-08, 09:42 AM
HotxxxxxxxOKC's Avatar
Ignore one set. Just put your black wire on the brass screw, white on silver.
Old 11-07-08, 10:11 AM
Thanks, just wanted to make sure...
And should it be put side by side
X X
O O
or one top and one bottom
O X
X O
Just having 1 set of wires will power both plugs?
Old 11-07-08, 10:16 AM
Gunguy45's Avatar
Super Moderator
Doesn't matter..if you look closely at the sides there are metal tabs that connect the screws.
If you've ever had a outlet that had the top controlled by a switch and the bottom always hot, those tabs are broken off and it has 4 wires connected. Not trying to confuse...just for information.
Old 11-07-08, 10:22 AM
thanks for helping out the amature... have a great day!
Old 11-07-08, 10:32 AM
You only have 2 wires (i.e. no ground wire)?
If so, just wanted to check that you're putting in 2 prong outlets.
