30/50 amp split breaker
I got a 100 amp service panel at my house with 30 amp and 50 amp circuits in it. It is full and I need to add a 50 amp circuit for my welder. I talked to a couple of electrians and they said to add a sub panel. That sounds right to me but then one said the they could replace the 30 amp double pole breaker with a 30/50 amp quad-pole split breaker and I wouldn't need a sub-panel. It would be alot cheaper that way but don't really know if that is safe. Any thoughts?
craig
Beer 4U2
craig
Beer 4U2
It depends on the make and model of the panel; let us know what you have and we can tell you if the quad breaker will work and be safe. The panel number will usually include a four digit code like ___3040__ which means 30 spaces and 40 circuits and implies up to 10 tandem breakers are allowed. You would also need a quad breaker which has CIT (common internal trip) on both "sides" which could be a hard part to find in those amperages.
If you panel allows tandems, another option may be to move some of your other general-purpose circuits to single-pole tandem breakers such as 20/20 or 15/15 to make room for a full-sized double-pole 50A breaker, depending on availability and price of a 30/50 common internal trip breaker.
