Requirements for wiring baseboard heater
Old 11-17-08, 10:09 AM
doublezero's Avatar
Received 2 Votes on 2 Posts
I am about to rewire 2 baseboard heaters. Both of them are attached on the same circuit. I am rewiring them because the idiot who wired them in the first place felt that it would be easier or cheaper to cut a hole out of the house, run the cable through steel conduit attached to the exterior brick, and then cut another hole in the attic where the cable re-enters the house. Then, he ran the cable under the floorboards over to the crawl space where they were all taped together, not even inside a junction box.
The cable is 12-2. My questions are:
1. is this the correct cable, or should I use a different gauge?
2. Do these baseboard heaters have to be on a separate circuit, or can I create a new outlet for a receptacle box off of it? I am asking this because I would like to also use this 12-2 circuit for a laundry machine. The heaters won't be running all the time, and neither will the laundry machine. So can I put them both on the same circuit?
3. The original circuit was 15A. Shouldn't you use a 20A circuit for 12-2?
4. Do I require an arc fault circuit, or a ground fault circuit, or none of the above?
Old 11-17-08, 11:13 AM
I
Received 45 Votes on 43 Posts
As you may already know NMD "Romex" cable cannot be used on the exterior of the building, so if you re-use this conduit you'll need to use a waterproof cable like UF-B or THWN conductors for the outdoor portion.
What is the wattage and voltage of the heaters? The #12/2 cable can support up to 3840W of 240V heaters or 1920W of 120V heaters.
The heaters must be on their own circuit(s) depending on the answer to #1. The laundry must have it's own 20A circuit with #12 wire. Code is specific on both of these.
12/2 is good for 20A maximum, you may use it for less.
Neither unless the heater is in a bathroom, in which case please specify as there are a few more details to cover.
Old 11-17-08, 11:27 AM
doublezero's Avatar
I'm not planning on running it through the conduit. I'm going to run the cable behind the walls, like everything else in the house. I don't like the idea of running cable outside, along the wall. The conduit was corroded and there were holes in it. I think it's a dumb idea in the first place.
I don't know what the wattage or voltage of the heaters is - people have painted them so many times, the specs are covered in paint or else they are somewhere hidden.
Thanks for the info on the circuits. I'll run a separate one for the laundry receptacle.
Old 11-17-08, 05:15 PM
pcboss's Avatar
Received 148 Votes on 131 Posts
Baseboard heaters here in the US draw 250 watts per foot.
