Old House-Outlets protrude from the baseboards
Old 11-19-08, 11:20 AM
For the most part my home has two prong outlets although a few have been upgraded to grounded 3 prong outlets.
Most of the 2 prong outlets are the more modern white/cream colored 2 prong receptacles that you still frequently see in older homes, but a few of them are older.
I am not sure when the house was built but based on the other houses in the neighborhood that are similar, I think it was in between 1935-1950.
In the living room, there are several outlets that run along the baseboard. Some of them are what I think are antique parallel/tandem outlets, but 3 of the outlets actually protrude from the wall and have a 3 sided face with a 2 prong outlet on each side. It looks something like this.
[IMG][/IMG]
These seem very dangerous. They are not grounded and if you plug in a two pronged plug like a lamp for example, the plug often becomes loose and falls out of the socket.
How can I replace these? Will they have a metal box behind them or is the box inside the receptacle that is protruding from the baseboard.
Any help would be greatly appreciated.
Old 11-19-08, 11:46 AM
Sorry, here is the drawing. The outlet is dark brown/black and looks like this.
Old 11-19-08, 12:06 PM
G
Received 20 Votes on 20 Posts
I couldn't access you pictures, but from what you say, the old receptacles that don't hold a plug tightly should be replaced. 2-prong ungrounded receptacles are still sold, and that is what you should use unless you upgrade the wiring (which might involve some major work).
It isn't kosher to just replace a 2-prong receptacle with a 3-prong receptacle (unless it is a GFCI and marked "no equipment ground"). You said that some of the receptacles had been upgraded to grounded types - you should verify that those receptacles are, in fact, grounded.
Doug
Old 11-19-08, 12:10 PM
Gunguy45's Avatar
Super Moderator
Received 4 Votes on 4 Posts
I saw the pic earlier, but not now...hmmmm..and I remember those in some old houses. Not an electrician, so can't advise as to what may replace them.
I think the site is having a little upgrade or problem...sure is looking funny on my end.
Old 11-19-08, 03:49 PM
ray2047's Avatar
Received 15 Votes on 13 Posts
Are you sure the ones that protrude aren't just screwed to the base board? If they are the ones I'm thinking of there is a screw holding the cover on and when you remove the cover you will see a metal plate containing the components screwed to the base board.
Old 11-20-08, 05:23 AM
Thanks I will check this out.
