Just want to confirm... (subpanel)
Old 12-01-08, 04:51 PM
TomZ1's Avatar
...my understanding.
Subpanel in a separate building (shed). If it has more than 6 circuits it needs to have a disconnecting means.
I take this to mean a sub with more than 6 circuits (throws) would actually have to be a main breaker panel rather than a main lug panel.
Correct?
Old 12-01-08, 06:23 PM
Tolyn Ironhand's Avatar
Received 92 Votes on 82 Posts
Correct.
You can back feed a breaker rather then use the main lugs. Or you can buy a separate disconnect and run from the disconnect to the panel.
Many times a main breaker panels are a better value than a main lug anyway. It doesn't matter if you put in a 100 amp main breaker when your are feeding it with say, a 60 amp feed. As long as you protect the feeders with the correct sized breaker, the 100 amp is acting as just a disconnect.
