my ceiling light won't work
Received 0 Votes
I took down an old florecent light fixture and I tried to replace it with a new light fixture but for some reason the new fixtures will not work on the wiring where the old light fixture was. I moved the new light fixtures to other wiring (black/white/ground) and they work fine. Does anyone have an idea why my wiring where (black/white/ground) the old light fixture was (working fine before I took the old fixture down) would suddenly stop working?
Received 0 Votes
Have you determined whether current is flowing in the wiring where the old fixture was? I use a non-contact detector that starts beeping when you hold it near a live conductor, even through the plastic insulation.
