Generac 10000 EXL Generator
Old 12-28-08, 03:46 PM
C
I have a Generac 10000 EXL generator that was working fine and all at once I lost all electric to all the outlets. Checked the resets on the front panel and all are good. Where do I go to next or check?
Old 12-29-08, 07:18 AM
W
Received 1 Vote on 1 Post
This is a wiring diagram for a 7500. I'm sure there's not much difference in your and this other than what's required for more output. Scroll to the bottom
http://www.generac-portables.com/doc...19_1ENW_LO.pdf
Old 12-31-08, 01:25 AM
N
How long has it been since this generator has been operated? Generators will lose their excitation after long periods of non-use. There is an easy trick to restore this, let us know if you find anything else after looking at the wiring diagrams. Also, check the brushes, they may need to be replaced.
