Home for doorbell transformer
Received 0 Votes
I am getting ready to drywall my basement but I need a home for the doorbell transformer. An outlet box is nearby but if the transformer fails I assume I won't be able to get at it. My other option is a nearby ceiling canned light. Can I use this box without a problem? I suppose my other option is to do a junction box in the ceiling and run a long wire (40 ft) to my workroom where I have several accessible options.
Any tips or ideas are much appreciated.
If your transformer is typical, it's mounted on the outside of a box, correct?
It draws so little power that it can be mounted just about anywhere there's a lighting circuit or receptacle circuit. Rather than run 120 VAC the 40 feet to your work room, consider mounting the transformer to a box in the workroom and moving the low-voltage wires. If you have to splice the low-voltage wires, make sure they're accessible.
Received 0 Votes
I like both ideas - thanks. I think I'll try to splice the low voltage doorbell wire in the nearby outlet box and then run a low voltage wire to my workroom. Thanks again.
There is other option you can go is if your breaker box is surface mounted then you can able use one of the konckout and mount the doorbell transfomer there and yes it is common pratice to do that.
Merci,Marc
Merci,Marc
I had to replace an old 10v transformer to operate a modern doorbell (16v) at my SIL's house in Denver a month ago. Like to NEVER have found the transformer. Thought it was in the attic above the doorbell...Noooo. Behind the zip box.....Noooo. It was 3 floors down next to the furnace on a J-box with a service receptacle. Go figure.
Rick just for my knowledge wouldn't the exception be if the box was only to house the transformer and only 120 was to the primary or am I wrong?
