What do I need 6-3 or 6-2 NM?
Old 01-22-09, 07:41 PM
I've read many posts here, I think I have an answer to my question but let's see.
I want to run a straight 50a circuit off my main panel (I have room/capacity) for a plasma cutter. The peak input amperage at max rated output is 34amps. It came with a CSA 6-50P - like many welders. If its dedicated as a "welder" circuit, I should only require a run of 6-2NM, correct? Pricey difference between 6-2/6-3...
Also anyone have suggestions for where to purchase wiring online - thinking it may be cheaper that HDs price of $1.97/$2.56/ft respectively.
(I know it may be a little overkill, I think 8NM is all that is required for 40AMPs)
Thanks,
Mike
Old 01-22-09, 08:14 PM
Tolyn Ironhand's Avatar
Received 283 Votes on 247 Posts
6-2 with ground is correct for your application. Unlike a range, your plasma cutter does not require a neutral.
Old 01-23-09, 11:31 AM
Thanks Tony - just thought I'd check to be sure before I purchased...
Mike
Old 01-23-09, 12:34 PM
I
Received 44 Votes on 42 Posts
#6-2 is the correct cable.
$2/ft is reasonable for that size. Wire price is basically tied to the market price per pound of copper so you aren't going to find major deals. With shipping cost, I doubt anyone can beat a local price, of course it can't hurt to check the supply houses too. If your required length is just shorter than a standard length, it will probably be cheaper to buy a packaged coil than pay per foot.
Old 01-23-09, 12:50 PM
Thanks Ben,
Yeah, I know I probably won't find any big deals
Funny though, when I was at HD looking for the 6-2, I happened upon a "remnant" 28' feet of 10/4 type SOOW 600V power cord. I've been contemplating making a 30a extension cord for my welder, as it turns out, this is the exact Carol cord that came with my welder..woohoo. Offered him a $1 a foot (which was maybe $.50 off) and he took it..
Mike
Old 01-23-09, 05:38 PM
28" of SOOW 10/4 cord for $28. Thats a good deal.
BTW - Not sure if you bought the wire yet or not but check the boxed prices. A lot of times you can get a much better deal if you just buy say a 50' box of boxed wire compared to the stuff they cut for you. Even if you don't use it all the still may be cheaper.
Old 01-23-09, 06:22 PM
Toyln,
Nice tip - I'll check into that. I remember seeing some 100' rolls, but it was all 6-3. May still be cheaper to buy it, use what I need (even though I only need 6-2) and sell the rest. Can't recall the price though.
BTW - Sorry, think I addressed you as Tony in an earlier post.
Mike
Old 01-23-09, 09:22 PM
Mike
No problem. It happens ALL the time!
If they have 6/3 they should have 6/2.I checked the HD page an they only list the boxed stuff type UF. Do not get that! It is a huge PITA to work with. Maybe try another big box store? Lowes? Menards?
Old 01-23-09, 11:21 PM
F
Mike
However there is one little overlooked gotcha due I know the Cord manufacter and I do have the ampcapity listing somewhere in the other computer but you can not run full 30 amp with 10/4 SOOW more like about 25 amp IIRC if I read it right.
Anyway that is pretty good deal to grab that cord.
Merci,Marc
Old 01-24-09, 05:13 AM
[QUOTE
If they have 6/3 they should have 6/2.I checked the HD page an they only list the boxed stuff type UF. Do not get that! It is a huge PITA to work with. Maybe try another big box store? Lowes? Menards?[/QUOTE]
Yeah, for sure. I laid some UF some time ago (to wire a garage). I'm headed to Lowes today to see if I can find it.
Marc,
You are absolutely right, the 10/4 is only rated as 25amp cord from General Cables website "Carolprene". My welder is a Miller 200DX inverter drawing ~28amps at rated output (don't have the manual handy, but the power cord that came on the welder is Carolprene 12/4), and my plasma is a HT PowerMax45 drawing 28-32 at rated output. I think I'll be OK, since, aside from arc initiation and if I'm welding/cutting at full capacity for longer periods of time, the cable shouldn't see anything "continuous" over 25amp. Would you caution otherwise?
Appreciate both of your help!
Mike
Old 01-24-09, 10:11 AM
Just a prolog to wire shopping...
Went to Lowes this morning and the 6-2NM was $1.65/ft (much better than HD). I asked the wire guy if they sold it in rolls (50/100') and he said no - how much you need? 60ft I tell him. Can you do any better on the per/ft price by chance, I say. So after BS'ing about home projects, he says, tell you what, I'll sell you 60ft for the price of 50ft .
So ended up paying $1.38/ft.
Never know unless you ask sometimes
Old 01-24-09, 12:01 PM
You sir, are my hero! Beer 4U2
Old 01-25-09, 08:53 AM
:NO NO NO:
Hero? Not quite, just got a little lucky!
Take care,
Mike
